Runnin' Rough
Old Sep 27, 2008 | 06:43 PM
imjrk's Avatar
Default Runnin' Rough
'96 Accord, VTECH, auto: replaced engine, hopefully have all wires and vacuum lines correct. Engine starts and idles just fine, can let it idle for 10-15-20 minutes and it still idles smooth as silk. As soon as I drive it a few yards the idle becomes really rough and drops to less than 500 RPM and stalls unless I keep some pressure on the gas pedal. The idle stays rough and very low until I shut it off and let it get stone cold. Then the proccess begins all over again, as soon as the engine warms to operating temp AND I drive it a few yards, the idle goes down and gets rough. This has me perplexed, I can idle it all day and it is fine, put the trans in drive and it goes BAD. Check engine light is on throws a PO135 code. Thanks, any help would be greatly appreciated.
Old Sep 28, 2008 | 01:50 AM
deserthonda's Avatar
Default RE: Runnin' Rough
code p0135 is for the primary heated o2 sensor,, you might want to chk it out
Old Sep 28, 2008 | 10:06 AM
imjrk's Avatar
I may have found it, bad battery. Had to jump start it, this final time I left the charger on it while I ran it, it did not run rough after I put it in drive after it warmed up like every other time (I have it up on jack stands).
NEPORTLANDMV
Apr 27, 2012 12:21 AM
Jsteves89
Apr 17, 2011 09:33 PM
jipmpizzle
Jul 5, 2007 03:40 PM
thejestersrace
May 26, 2005 09:21 PM
mbliss
Dec 18, 2004 01:33 PM
