power steering
Old Sep 28, 2008 | 12:19 PM
79pete
Default power steering
so my girlfriend has a 2003honda accord. I started it the the other day and the power steering pump was whinning bad. I opened the resevoir and the fluid was brown and foamie. once the motor reaches temp the noise stops.I have been sucking out the resevoir and replacing with fresh fluid. I have gone throughtwo quarts now and problem still there. possible contamination/water???. any ideas would be helpful. thanks
Old Sep 28, 2008 | 12:20 PM
Default RE: power steering
sounds like air in the system to me. i would fill it back up, then just start the car, and turn the wheel from lock to lock for a few minutes and it should bleed itself
Old Sep 28, 2008 | 12:27 PM
79pete
i have been doing this for about two weeks. i will drain the resevoir and refill then drive it for a day or two and repeat the process. still no change. any other ideas and thanks for the reply.
Old Sep 28, 2008 | 01:15 PM
Somewhere in system (suction side) the pressure is below atmospheric and air is being pulled into the system. Check all suction side hoses and connections carefully. There is a filter of sorts in the bottom of the reservoir, that if paritally blocked might make the problem worse. You may want to replace reservoir.
amajakgar
Aug 9, 2014 09:22 AM
loki16
Aug 12, 2013 06:54 AM
darkgreen18290
Jun 25, 2013 07:51 AM
Planefreak
Nov 15, 2007 02:52 PM
