power steering
so my girlfriend has a 2003honda accord. I started it the the other day and the power steering pump was whinning bad. I opened the resevoir and the fluid was brown and foamie. once the motor reaches temp the noise stops.I have been sucking out the resevoir and replacing with fresh fluid. I have gone throughtwo quarts now and problem still there. possible contamination/water???. any ideas would be helpful. thanks
Somewhere in system (suction side) the pressure is below atmospheric and air is being pulled into the system. Check all suction side hoses and connections carefully. There is a filter of sorts in the bottom of the reservoir, that if paritally blocked might make the problem worse. You may want to replace reservoir.
amajakgar
Aug 9, 2014 09:22 AM
darkgreen18290
Jun 25, 2013 07:51 AM
thunder_x
Aug 11, 2007 10:31 PM
