obd scanner
Old Sep 12, 2010 | 02:51 PM
stevee1953's Avatar
Default obd scanner
Hi all,im interested in buying a fault scanner,i have a 99,accord es saloon,2.0ltr,but most off the scanners ive seen say they only work with cars 2001 up,but i have a diagnostic plug pass side on tunell,so does anyone know if,they will work,and any pointers to a good one,,cheers for any answers,oh by the by i am in uk,and its uk spec,
Old Sep 12, 2010 | 06:27 PM
You should be good since your 99 is OBD2 compatible, however I would suggest you check the scanner specs before purchasing. If you just want to extract fault codes and reset ECU, there are many choices for <$100.
If you want to see more information such as mass air flow, coolant temp, O2 sensor voltage, etc you will need a more capable OBD2 scanner. Here you will be spending upwards of $200 to the sky. I purchased a Harrison R&D OBD2 scanner several years ago and it worked well until I purchased a 2007 Accord and 2003 Acura MDX. It would not work w/ these vehicles. I purchased an updated model from Harrison R&D and it works fine. My cost was $160 for scanner interface and $100 for a used laptop to receive and interface w/ scanner interface. This is only one option among a multitude of OBD2 scanners.
Old Sep 14, 2010 | 12:32 AM
stevee1953's Avatar
sorry for late reply texashonda,got called away,so only just read now,,i will need one,some joker has removed the mil light from dash,so i put a new one in and its staying on??so i really need one to point me in right direction(hopefully).thanx again for advice,appreciated..
Old Sep 14, 2010 | 06:44 AM
I don't know about this in UK, but around here there's several car-parts chain stores (AutoZone, O-Reilys, etc) that will plug in a reader & read the error codes for free (hoping you'll buy parts from them).
jrobida
Mar 25, 2016 10:15 AM
Crocen
Dec 27, 2012 09:47 PM
TahoeTexan
Jan 6, 2009 02:31 PM
Treaddirt
Oct 9, 2006 01:10 PM
sir_nasty
Mar 17, 2006 01:50 PM
