OBDII READINGS
Old Dec 17, 2007 | 08:27 PM
pjlooby
Default OBDII READINGS
I'm looking at buying a 1997 Accord LX. I have an OBDII reader and get no codes...but the reader also willdisplay all the engine parameters while it is running and I was wondering if there is a list of what the readings should be on this car to have a better idea of whether all these things are within specs. I see a lot of "n/a"s and just wonder if that is normal also. Thanks.
Old Dec 17, 2007 | 09:27 PM
Default RE: OBDII READINGS
Give us an example of an item that says"n/a". If it'sa generic scan-tool (not specifically Honda) it probably would show that for certain sensors that don't even exist on your car.
For example your car doesn't have an air mass-flow sensor, but lots of cars DO. Some cars might have as many as 4 oxygen sensors where yours has 2.
Old Dec 18, 2007 | 07:03 AM
pjlooby
When I looked at the carI didn't really make noteof anything I could give as an example. Sorry. But what you're saying makes perfect sense since it is a generic reader from AutoZone. The other things are more of what I wastrying to get some parameters for(coolant temp...rpm...advance degrees ect.) Thanks for your reply.
Old Dec 18, 2007 | 09:12 AM
00AccordLX5spd's Avatar
Registered User
"n/a" probably means "not applicable"
Old Dec 18, 2007 | 10:08 AM
finch13's Avatar
I think the 97's are OBDI, not OBDII, so they don't report that much info to a scanner.
Old Dec 18, 2007 | 11:25 AM
klrspz's Avatar
# 1996: The OBD-II specification is made mandatory for all cars sold in the United States.
Old Dec 18, 2007 | 07:12 PM
HondatechAV6's Avatar
fyi - honda didn't comply with obd2 regulations completely in 96. that's why everyone has a free tune up and emission warranty for 15yrs/150,000 miles. [8D]
Old Dec 18, 2007 | 08:01 PM
nafango2's Avatar
im pretty sure they did in all the US models...
maybe int'l models they didnt...
otherwise they wouldnt have been for sale... cuz its a law...
thats like installing fake airbags as far as the NTHSA is concerned.
Old Dec 18, 2007 | 10:01 PM
ORIGINAL: 00AccordLX5spd
Hey Jon, did you figure that out all by yourself?
(j/k, couldn't resist...)
If the car was still OBD-1, he wouldn't even be able to plug his scanner in. The plugs are very different.
Honda even went OBD-2 early, in Jon's case ('95 V-6).
Old Dec 19, 2007 | 07:49 PM
it has an obd 2 connector of course, they just didn't fully comply with the regulations.
Drake Duncan
Apr 27, 2015 07:53 AM
tqriddle
Aug 24, 2009 10:23 PM
tqriddle
Aug 22, 2009 05:14 PM
usaccordinjapan
Dec 17, 2008 06:12 PM
Erinsaccord
Aug 14, 2007 08:50 PM
