OEM vs Aftermarket Intake
Old Jan 29, 2018 | 09:53 AM
TexomaAccord's Avatar
Default OEM vs Aftermarket Intake
1997 accord 2.7l -- noticed my air intake tube is ripped.. Replacement for OEM is 47.00 --- One of those "cold air intake kits (metal tube, clamps, filter)" is 27.00
Now, question is.. Im on a budget, if I went with the cheaper one, will there be any difference in the way the car drives, sounds, etc? Or should I spend the extra and go OEM?
or should I just glue together my factory one and go on about my business?
Old Jan 29, 2018 | 01:11 PM
shipo's Avatar
As a general rule, aftermarket intakes are louder and yield significantly degraded filtering; you won't notice any difference in performance unless your Butt Dyno equates the extra noise with extra power.
Old Jan 29, 2018 | 08:35 PM
Installing a cold air intake puts you at risk for pulling a slug of water into the engine if you went through a big puddle.
I'm a fan of going OEM. You could probably get away with heavy duct tape on the intake tube to fix the problem.
award78
11
Aug 27, 2008 08:38 PM
top end ms
Feb 14, 2008 12:35 AM
62maxx
Oct 2, 2007 02:53 PM
MakoMan
Jan 29, 2007 11:31 AM
jastunna1987
Sep 9, 2006 07:00 AM
