Oil
Old Aug 27, 2011 | 04:20 PM
Quicksilver436's Avatar
Default Oil
Going in next week for the '11 Accords ELX-V6 first oil change.....
Does anyone use synthetic in lieu of the regular Honda brand oil that the dealer uses. I believe that the dealer stocks and will use a Honda fully synthetic brand upon request.
Old Aug 27, 2011 | 05:32 PM
Kind of a debate. Use the proper weight, syn or dino???.....again, go with the what is suggested in the owners manual and you will be good.
Old Aug 30, 2011 | 02:52 PM
Default Oil
Oil change completed. I went with the fully synthetic. I do not know about all Honda engines but for the new V6s, Honda uses a synthetic/dino blend. The manual states that full synthetic may be used at the owner's option.
The dealer could give no good reason for the manual's statement in the break in section stating that oil should not be changed until so directed by the maintenance minder.
Old Aug 30, 2011 | 06:07 PM
Good to hear and thanks for the update.
Old Aug 31, 2011 | 07:50 AM
tradosaurus's Avatar
If you are changing the oil every 3,000 miles or 3 months then synthetic is a waste of money.
I personally would go 12 mo/12,000 miles on a synthetic oil change which then makes the extra money worth it.
MiyashiMeism
Sep 5, 2010 02:12 PM
jasonan
Aug 28, 2009 11:26 PM
Karthigan
Nov 27, 2006 02:55 PM
thunder_x
Oct 22, 2006 09:56 AM
nygamble
Jun 11, 2006 07:13 PM
