Oil Change after Techron use?
Old Jan 11, 2008 | 11:26 AM
crvone's Avatar
Default Oil Change after Techron use?
Hi All,
I plan to use Techron Concentrate in my next fill-up. I remember hearing one should then change theengine oil after the second tank of gas. Is this true? why?... is it because somewhat the fuel/additive gets into the oil?
... thanks in advance.
Old Jan 11, 2008 | 04:02 PM
Default RE: Oil Change after Techron use?
I don't always do it. I think the reasoning is that the Techron is more likely to wet the cylinder walls & from there get into the oil. I bet most of it burns up, but I haven't done any oil analysis to prove that.
Old Jan 11, 2008 | 04:31 PM
Gopal's Avatar
ORIGINAL: crvone
Hi All,
I plan to use Techron Concentrate in my next fill-up. I remember hearing one should then change the engine oil after the second tank of gas. Is this true? why?... is it because somewhat the fuel/additive gets into the oil?
Even if it is true, may be you can plan to pour in the Techron couple of gas-fills before your next oil change.
PinkFloridaFlamingos
Aug 24, 2011 12:35 AM
MessAround
Jul 29, 2011 11:17 AM
KincaidChance
May 3, 2011 01:13 AM
chris h
Apr 3, 2011 10:01 AM
