oil / filter
Old Dec 14, 2008 | 11:11 AM
Driving me nuts's Avatar
Default oil / filter
My car calls for 5W-30 oil. Does it matter if I get it at the Auto parts store of does it need to be "Honda" oil ? What about the filter, I read in a post that it should be OEM ? Thanks
Old Dec 14, 2008 | 11:24 AM
hondadude's Avatar
Default RE: oil / filter
Oil from the parts store is okay, Castrol GTX is my favorite flavor.
The oil filter from Honda has a relief valve in it, so that even if the filter gets plugged up the oil pressure will allow oil to still be delivered to the engine.
Unfiltered oil being better than no oil at all.
Also the filter media/construction is a better grade.
Years ago I worked at a shop that had a bandsaw, cutting cases off ofoil filters reveals information not shown in advertisements.
For instance, I would not put a fram filter on a lawnmower engine; Glued together paper, no relief valve.
Old Dec 14, 2008 | 12:39 PM
ORIGINAL: hondadude
amazing quote
royal purple is my favorite.........but its expensive. I also dont mind mobil 1, and for non synthetic valvoleen cause it has the least amount of additives in it.
Old Dec 14, 2008 | 07:23 PM
cjdm98's Avatar
Im a castrol Guy,both conventional,and syntec.
With Mobil 1 filter.
Old Dec 14, 2008 | 08:18 PM
drummer1279's Avatar
Castrol high Mileage and purolator filters on mine, 235,000 and counting
Old Dec 15, 2008 | 01:07 PM
I've always used what was on sale as long as it met my specification and viscosity requirement. I've used Walmart, Quaker State, Penzoil, etc. I like the Walmart filters and oil just fine. However lately you can do just as well at O'Riellys w/ an oil change special; Microline filter and O'Reillys oil.
Obviously I don't think oil brand is as important as changing regularly.
I'm at 225K miles on my 94Ex.
Regards
Old Dec 15, 2008 | 01:15 PM
finch13's Avatar
Anyone ever used the Ford Motorcraft synthetic oil? I bought it once when Mobil1 was like $35 for a 5 qt. jug... it seemed okay, but I was a little weary at the $11/jub pricetag for full synth....
falkore24's Avatar
Amsoil FTMFW!!!! Royal Purple uses a ton of Moly ... booo for a DD. M1 is good ...... then again, any dino oil will go 5000 miles without any problems, so for most people, Jiffy lube is fine. Motors that hiss and spool should have synthetic, no questions asked.
Old Dec 15, 2008 | 01:17 PM
What about Motul? or royal purple racing formula, are those good for dailys lol
11_22_1992
Jun 19, 2015 12:20 PM
Special_K
Aug 12, 2011 04:16 PM
bjr001
Mar 5, 2010 07:31 PM
noboundaries6289
Mar 29, 2007 05:32 PM
nygamble
Jun 11, 2006 07:13 PM
