Oil Leak
I have a 2004 Accord 6 speed coupe... I am getting an oil drip that appears to be coming from around the clutch inspection cover, I believe. I have not yet received my factory shop manuals to look for a scource, so any ideas? Is this a common problem?
Thanks in advance!
[align=left] [/align]
Thanks in advance!
by clutch inspection cover are you referring to the opening between the tranny and engine that is used for setting the timing?
can you get us a picture?
No common oil leak areas that I know of on 04's...
Sorry, I should have included the picture. Hope this explains things better! Also my first picture post here.
[IMG]local://upfiles/14210/7BA5D9A1529446DD993FE8E65052A884.jpg[/IMG]
[IMG]local://upfiles/14210/E375F49D85C24A0C9241E8E73623AFC3.jpg[/IMG]
Kinda looks like it's running down the engine from somewhere up top but I could be wrong.... if it is from that area and it's coming from inside I'd venture to guess that it's a rear main seal.... However, I sincerly hope I'm wrong.... Give it a bit and see if someone else has an opinion....
[align=left]
Yeah, my thought also... I looked around as much as I could, but did not seem to find any from up top. I will look again in the morning.
I just hate to think a rear main seal with only 50k miles...
[/align]
[/align]
xaznxeclipsex
Sep 28, 2007 02:05 PM
