Oil leaks
Old Sep 2, 2012 | 09:04 AM
norbertocartagena's Avatar
Default Oil leaks
I have a 2002 honda civic and leaks oil thru seals due to crankcase air pressure ? I was told by a mechanic that it need a rebuild. ( I don't think so ! )What should I do
Old Sep 2, 2012 | 11:15 AM
try replacing the pcv valve
Old Sep 2, 2012 | 12:55 PM
Silver6gen's Avatar
how many miles are on your car? Try replacing the PCV valve its cheap and is designed to "pull" the extra pressure out of the case.
The reason your mechanic told you that you need a rebuild is because the pressure is created by piston blow by from a worn out engine. Do a compression test after you replace the PCV. Search ericthecarguy's youtube page for instructions on how to do a compression test.
ccookie66
Apr 12, 2019 04:43 PM
Jay 3rd
Dec 29, 2008 11:39 AM
RA1525
Mar 11, 2008 07:02 PM
longneck8769
Mar 28, 2006 06:19 PM
longneck8769
