Oil pan gasket, exhaust down pipe
Old Oct 13, 2010 | 07:54 PM
wunderbra's Avatar
Default Oil pan gasket, exhaust down pipe
Need to replace the oil pan gasket on my 94 Accord EX. There is an exhaust down pipe that I will probably need to remove to get access. Does anyone know if there are exhaust gaskets I need to order for that down pipe, when I re-install it? If so, where can I find them online. I live far from a Honda dealer, and the diagram I saw on line from the dealer site doesn't show the gaskets individually.
Old Oct 14, 2010 | 12:04 AM
Question Hi Member
Don't you have a parts store close to your living area somewhere's?
Old Oct 14, 2010 | 12:46 AM
deserthonda's Avatar
i have reused those gaskets with no exh leaks after reinstalling ,,
Old Oct 14, 2010 | 05:40 AM
wunderbra's Avatar
I did find some on a parts website I have had good luck with, Partsgeek. The local parts store is hit or miss with the correct application on Japanese car parts and cost about what a dealer charges, for the privilege of waiting for UPS to deliver to their shop. There is also Auotzone- but the quality of their gaskets suck! I know this from experience.
Old Oct 14, 2010 | 07:34 AM
www dot hondaautomotiveparts dot com
www dot manhonda dot com
I've reused the similar gaskets on an Integra, but there's always some risk that they come apart on you.
Also I think there might be little steel rings embedded into the pan gasket, around each bolt. Make sure they come off with the gasket & don't leave them behind to mess up the new gasket.
Old Oct 14, 2010 | 04:50 PM
wunderbra's Avatar
Thanks for the tip on the steel rings. Will the new gasket have them?
Old Oct 14, 2010 | 04:58 PM
Maybe... If not, then the old gasket probably doesn't have them. I don't remember if ALL cars ALL years have that. My 95 Integra had them.
ccookie66
Apr 12, 2019 04:43 PM
frost506
Jan 16, 2012 07:21 PM
meazz1
Feb 21, 2006 09:25 PM
mcrisost1999
Jul 10, 2005 07:13 PM
Shocker
May 4, 2005 02:03 AM
