Oil in spark plug tubes...
Old May 28, 2013 | 03:10 PM
Novaknowledgenow's Avatar
I wouldn't put anything on them really, maybe the smallest amount of oil to help it thread just right.
I will say this, if you found several screws "not even hand tight", someone was probably not paying attention when they were replacing the last set of seals.
I would do it by spec for tightening it up, then check it next oil change. I'm sure it will be good to go if you have a new valve cover gasket on it.
Also, make sure the nuts on the top of the cover are tight, as that will let oil in several tubes at a time if they are loose.
If you tighten them right, they should stay that way.
Old May 28, 2013 | 08:48 PM
EXV6NIGHTHAWK's Avatar
I think the valve cover nuts are only supposed to be torqued to something like 7 ftbs. If you don't have a small torque wrench, I would suggest using either a 1/4" drive ratchet, or socket screw driver to tighten so you are less likely to put too much force on them. Turn them down evenly, a little at a time. Good luck
bigdawg74
Jul 30, 2011 06:50 PM
19Accord97
Jul 28, 2008 10:56 AM
MALSR
Jan 5, 2007 04:59 PM
patcal
Nov 27, 2006 11:33 AM
deserthonda
Apr 16, 2006 04:22 AM
