Oil on spark plug wires (bootside). What to do??? pls HELP!
Old Jun 9, 2006 | 07:56 PM
jrcastro's Avatar
Default Oil on spark plug wires (bootside). What to do??? pls HELP!
Just bought a 92accord with 150k miles for $2300 last night. This morning I noticed that that there is oil in all 4 plug wires. I have read that it is most likely the tube seal under the valve cover.
Questions are:
Is this a big hazard for the engine?
What can be the results if not fixed?
Should this be fixed asap?
How long can I drive in this state?
Car runs good, no misfiring & no hardstarting.
I read some of the maintainence recs. & it shows valve cover gasket including tube seals were replaced Feb. 2005.
Maybe they did not do a good job!
Budget is kinda limited so if it is not a major concern I will put off for a few months (while monitoring the engine oil level carefully).
Thanks in advance
Old Jun 9, 2006 | 08:22 PM
sir_nasty's Avatar
Default RE: Oil on spark plug wires (bootside). What to do??? pls HELP!
just watch your oil level and it should be ok. Also, there is a full write up from deserthonda on replacing those yourself... just do a search or look through the forum there is GREAT information on how to do that cheap...
Old Jun 9, 2006 | 08:23 PM
sir_nasty's Avatar
https://www.hondaaccordforum.com/OIL...m_16786/tm.htm
that's the link.. however if you look at the posts at the top of this section you'll see "oil in spark plug wires" how to fix.... *L* don't worry it's easy to do and fairly cheap
Old Jun 9, 2006 | 09:00 PM
jrcastro's Avatar
Thanks for the info. I thought i got burned! can you paste the link again? I'ts not working. TY
Old Jun 10, 2006 | 05:32 AM
deserthonda's Avatar
ORIGINAL: jrcastro
if you go to the DIY section and scroll down , you will find the link.......oil in spark plug wires,, Fix ,,
if any questions ,, ask away ..
sirtwist2
Sep 24, 2012 01:36 AM
wannakeepmy94Accord
Mar 14, 2012 08:06 PM
4thgenaccord88
Jan 4, 2008 04:51 PM
jrcastro
Jun 20, 2006 09:59 AM
deserthonda
May 12, 2006 03:14 AM
