Oil and Timing belt issue
Old Feb 4, 2010 | 06:30 PM
camoo's Avatar
Default Oil and Timing belt issue
My 01 honda accord was driving perfectly without any problems until I got the oil changed. Two weeks after a O-ring popped out and all the oil came out. I took it to a mechanic and he replaced the o ring and suggested I get a timing belt kit since the belt was covered in oil. Now when I drive it, the engine does not sound the same and is a lot louder. Could this be because of damage to the engine or something to do with the parts not being installed properly??
Old Feb 4, 2010 | 07:04 PM
Is the o-ring you are talking about one of the shaft seals inside of the timing belt cover?
If so, then I am guessing that the mechanic replaced the seal and both the timing and balance belt.
My guess is that the timing belt was installed off 1-2 teeth. Take the car back to the mechanic to get the timing belt installed properly.
Old Feb 4, 2010 | 07:22 PM
camoo's Avatar
It was one of the shaft seals. They did replace both of them. I will take it back to him and have him make sure it was installed correctly.
Does having the belt off 1-2 teeth cause any damage to the car?
Old Feb 4, 2010 | 07:43 PM
It will run poorly. I would not drive unless necessary. I don't think being off a tooth will cause valve damage.
john_pyro
Aug 4, 2019 05:06 PM
Bange
Oct 12, 2014 06:27 AM
wendellanderson2009@hotmail.com
Jun 22, 2012 02:49 AM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
