Oil in tube 2002 Honda Accord LX 4 CYL
Old Feb 27, 2021 | 05:34 PM
PDIM69$'s Avatar
Default Oil in tube 2002 Honda Accord LX 4 CYL
Started misfiring on # 3 Cly. , Noticed oil in the spark plug tube. I installed new upper seals , cover gasket and spark plugs. Car ran on all 4 for a little while and started to misfire again. I again noticed oil in the tube. First thing to come to mind was does it have lower seals ? Depends who you talk to and maybe a crack in the tube. Can somebody please tell me if iit does have lower seals..
Txs,
Paul
Old Mar 1, 2021 | 05:22 PM
It does not have lower seals. That stopped a couple years earlier than your car.
Are you sure you installed the upper tube seals right-side-up? And if I remember right, they're a bit tricky to get them to stay in the right place as you lower the valve cover down into position.
And, the smooth surface of the head (where those seals bear against) has to be clean and free from scratches.
kain9i6
Mar 16, 2012 03:19 PM
MessAround
Jul 1, 2011 12:34 PM
uraceulose
Nov 12, 2010 05:46 PM
Antarctica
Oct 19, 2009 10:37 AM
wsrr25
Jan 26, 2009 11:55 AM
