Oil (?) under the distributor
Old Nov 9, 2008 | 08:28 AM
abhijitgp's Avatar
Default Oil (?) under the distributor
Hello,
I have been meaning to ask this question, and it slips my mind every time. I have noticed oil or sludge around and under the distributor in my engine bay. It does not look like a normal thing but is it something I should be worried about? Is it possible to clean it? I was thinking of buying some de-greaser, spraying it on and around the distributor and then spraying it with water. I would appreciate experts opinions about this issue before doing anything like that.
Thanks
[IMG]local://upfiles/5264/F6CA3B3BB34B4801A09A73174B751DCE.jpg[/IMG]
Old Nov 9, 2008 | 08:47 AM
Default RE: Oil (?) under the distributor
There are two sources of oil leakage by the distributor. The distributor drive shaft has an oring where it engages the cylinder head and there is an internal oil seal in the distributor. Drive shaft oring is easy to replace by pulling distributor. The internal oil seal is quite involved, but if you're game I have a pdf file w/ instructions. Not terribly difficult but many steps.
Hard to be sure from a picture, but yours may be an internal seal leak. Oil appears to be draining from distributor housing.
Old Nov 9, 2008 | 08:52 AM
abhijitgp's Avatar
thanks for the quick reply, TexasHonda. Should I start with replacing the drive shaft O-ring first? Also, where can I find that PDF, just in case? and is cleaning that oil leak before doing anything a good idea?
Old Nov 9, 2008 | 08:56 AM
PM your email address and I'll forward the pdf file.
I agree you should replace the distributor shaft oring first. You can also remove distributor cap and check for oil inside the distributor. If yes, then internal seal has failed.
Old Nov 9, 2008 | 05:08 PM
If it were the internal shaft seal, the oil would show up INSIDE the distributor.
Clean it up & watch where it leaks from. Take off the distributor cap & see if its oily inside.
Old Nov 10, 2008 | 07:19 AM
MikeT's Avatar
From my experience, I would just replace the entire distributor switching out the ignitor and module. I replaced the failed seal that causes the leak and ran into the other problem that the leaking oil causes. The oil will over time, cause the wire casings in the distributor to become brittle. When you go to replace the seal which really isn't hard, you will inevitably crack off the casings causing the wires to short out. Just order the distrubutor from Majestic Honda and be done with it.
Old Sep 29, 2011 | 08:43 PM
Ronnee's Avatar
Hi saw your messages re distributor with oil leaks have similar problem, could you send me a copy of pdf re 1994 honda accord distributor seals ring/shaft bearing etc would be most thankful ron
Old Sep 30, 2011 | 05:50 PM
There is a sticky at the top of this section, Common DIY Threads. In that, there is a post you can open and get the link to download directly to your PC.
....PS, Welcome the the site.
Old May 22, 2012 | 11:14 PM
tobytigger's Avatar
I can not find the PDF file that you indicated is in the sticky DIY section. Can you check it out and give me the thread name? Thanks
Old May 22, 2012 | 11:41 PM
It the common diy thread on top of the gen tech help forum. It has a link to online shop manuals.
mamtsberg
Jan 28, 2021 12:44 PM
timaccord
Aug 17, 2011 05:12 PM
Apr 14, 2009 08:12 PM
z00ropa
Jul 29, 2007 07:46 AM
daddy
Nov 30, 2006 03:37 PM
