Ok i got probs
Old Apr 30, 2012 | 05:38 PM
Ryan1984's Avatar
Default Ok i got probs
ok i got an 04 accord 4 cyl. CEL is on reads a bad barometric pressure sensor when i got it tested. cleaned everying that has to do with throttle body air filter nothing worked.I think i need a new ecu/pcm. On top of that lights dim while driving its annoying, i heard it was 'normal' not sure if i believe that. And for the final thing driver side window when it is rolled up (electric) it randomly every minute or so tries to roll up on its own. Any advice about any of this issues would be great.
thanks for your time
Old Apr 30, 2012 | 05:45 PM
crispin's Avatar
putting a bunch of problems in one thread does not normally work well.
Lets focus on one problem at a time.
Has this car been in a flood? I ask as you have problems normally associated with water intrusion.
Barometric issues with the ECU can only be resolved by replacing the ECU. The Barometric sensor is part of the ECU.
How long have you owned the car for?
Do you know the history for it?
Old Apr 30, 2012 | 06:05 PM
Ryan1984's Avatar
no dont know the history of it it was purchased at a dealership last march
Old Apr 30, 2012 | 06:12 PM
crispin's Avatar
ok - I am going to say your car was in a flood.
You need a new ECU
Check Ebay for one.
After you replace that report back with what problems you are still having.
Old Apr 30, 2012 | 09:35 PM
I also remember reading a thread where a leaking evaporator core can get coolant on the PCM. I can't remember what year accord, but it might have been an 03-07. Take a look at the pcm to see if there was coolant leaking on it.
mixedboydriver
May 20, 2011 05:14 PM
one35studios
May 16, 2008 10:20 AM
Eric24
Aug 14, 2006 02:53 AM
fire_walker_78
Aug 23, 2005 09:12 PM
