Only Honda ATF?
Old Jul 9, 2007 | 02:15 AM
lgetz's Avatar
Default Only Honda ATF?
High to all. I recently purchased an 02 EX 4cyl. w/ an AT. I haven't driven the car but 20 miles because it needs a few interior pieces. The car is a solid 8.5 looks wise. My question is do you all only recommend Honda brand ATF? Can I not use a Castrol brand at Advance Auto that states it is compatible? Don't mind spending the $$$ but only if really necessary. BTW I did a search and came up empty but plenty of vets stated "use only Honda ATF." Thanks in advance. (No pun intended)
Old Jul 9, 2007 | 05:37 AM
Default RE: Only Honda ATF?
All you can find will be reports that Honda ATF improved shift performance and corrected minor trans problems. You only need to change every 2-3 yrs, so not a major expense. I used Walmart ATF for several years in my 90 Accord w/o problems until I became a convert to Honda ATF. No particular reason except the testimonials were compelling.
Old Jul 9, 2007 | 06:39 PM
lgetz's Avatar
OK. Thanks TX Honda. I went and bought genuine fluid at the dealer. Not bad 3 qts. were about $18 dollars. Will be performing the change myself.
Old Jul 9, 2007 | 06:58 PM
hondadude's Avatar
The biggest reason for Honda ATF is the smaller lubricating molecules.
The shift valves fit into the valve body with no seals, just a very tight fit to the bore.
Cleaning properties come into play as well, any varnish build up will cause the shift valves to bind a little and shift slower.
Old Jul 10, 2007 | 12:17 AM
lgetz's Avatar
Well I got the tranny fluid changed. The old fluid was light reddish brown. Didn't seem too bad but I wanted extra piece of mind. BTW took a 30-35 mile drive and everything seemed well. Now as soon as I get the inside put together this will be the daily driver. Thank you both TX Honda & HondaDude.[sm=shades.gif]
curtie94
Jun 23, 2012 07:52 PM
moey
May 22, 2011 10:43 AM
markrb
Jan 27, 2011 11:25 PM
dknight211
Jan 22, 2008 06:35 PM
brave_mhy
Jun 29, 2007 10:34 PM
