Outside Temp. Sensor
Old Jan 18, 2013 | 01:29 PM
eugenechoi57's Avatar
Default Outside Temp. Sensor
I have 2005 accord ex-v6 coupe. Outside temperature doesn't show. How can I fix this?
Old Jan 18, 2013 | 05:27 PM
Display is blank or incorrect?
If blank, likely defective elements in display. If --- displayed, there may be an electrical fault. Have you checked temp sensor mounted behind front bumper? There may have been a fender bender and never repaired.
Old Jan 18, 2013 | 05:46 PM
Thank you so much!
Where is sensor located? And where can I get it at?
Old Jan 18, 2013 | 06:42 PM
Not sure exactly. I looked in my 2003-2007 Shop Manual for 4-cyl and it does not have a diagram or replacement procedure. It only says it's behind the front bumper. On other model of Acura/Honda it's in front of the condensor mounted on center vertical member. It's a little bulb-like object mounted on a bracket.
Old Jan 18, 2013 | 07:53 PM
rimidalvr1966
Oct 28, 2013 10:35 AM
colorado_accord
Mar 20, 2011 05:58 PM
Digit
Mar 1, 2011 08:47 PM
segen77
Dec 9, 2007 06:55 PM
longhornjohn
Aug 26, 2006 07:32 PM
