P0141 which sensor?
Old Feb 9, 2011 | 10:29 AM
sneekz206's Avatar
Default P0141 which sensor?
I am pulling up this code and not sure which sensor I should replace thats all my OBD is reading.
I do not wanna buy both so I need to know which one is the correct one. Front or Rear?
Thanks!
Old Feb 9, 2011 | 10:47 AM
P0141 = secondary O2 sensor heater circuit
That's the rear sensor, mounted in the catalyst. But that code doesn't necessarily mean the sensor itself is bad.
Got a multi-meter? Unplug the sensor and find the 2 same-color (black?) wires on the sensor-side of the plug. Measure resistance between them - it should be 10 to 40 ohms. A bad sensor will usually be open-circuit (no continuity).
If the sensor is OK, then you need to look at wiring problems in the car.
Old Feb 9, 2011 | 11:26 AM
sneekz206's Avatar
Thanks I will try and do that
pondrun
Nov 8, 2021 09:40 AM
amanb
Dec 14, 2008 07:14 AM
22R
Dec 12, 2008 06:28 PM
HORSEPOWERJUNKIE2007
Mar 31, 2008 04:53 PM
CasualObserver
Dec 14, 2006 02:06 AM
