P1457
Old Dec 3, 2007 | 08:19 AM
lucky777
Default P1457
P1457 came up on my 99 Accord LX 4 cyl. I've read that it can be a number of things. Not sure how diagnose this properly but I'm thinking to replace CVS first since it is most common part to go bad and there is a Honda TSB on that http://www.driveaccord.net/forums/at...7&d=1107021677
if that doesn't fix it then I'll try bypass valve and two way valve. Is there a good way to test these valves? I really don't want to replace a lot of parts for nothing and any troubleshooting advise would be really helpfull.
Old Dec 3, 2007 | 08:52 AM
deserthonda's Avatar
Default RE: P1457
ORIGINAL: lucky777
I have fixed a # of these and the only issue that i have found has been the evap bypass solenoid valve and the evap 2 way valve,, Now i live in AZ . i do not know wether in some other parts of the country rust might play a part in it,,
Old Dec 3, 2007 | 08:55 AM
00AccordLX5spd's Avatar
Registered User
Default RE: P1457
You are definitely on the right track there. have you tried simply clearing the ECU and seeing if the light comes back on? Try taking the gas cap loose and tightening it back down (till at least 3 clicks) then clear the ECU and see if the code comes back.
I know 1457 is not becasue of a loose gas cap(normally a 1456), but it is worth a shot since the procedure is free and super easy.
I wouldn't necessarily start replacing parts just yet. If I were you I would think about taking it to a shop that specializes in Hondas. Unless you can go junkyard diving and recover EVAP components for dirt cheap.
Old Dec 3, 2007 | 09:07 AM
lucky777
Default RE: P1457
I live in Ohio so we have snow and salt on the roads and TSB says that CVS is most likely cause of my problem (hope not PCM!). I was thinking about junk yards but afraid that valves from there can be bad but might be worth a shot if I get parts cheap. Can I use valves from any LX 98-02 on my 99 or I need parts from 99 only? I also reseted the light by pulling fuse #13, I'll see if it comes up back. Most likely it will.
Old Dec 4, 2007 | 08:39 AM
lucky777
Default RE: P1457
Does pulling fuse #13 clears the ECU or resets the light only? If it only resets the light, how to erase codes from ECU without the scanner?
Old Dec 4, 2007 | 08:47 AM
Registered User
Default RE: P1457
It resets the entire ECU I believe. Kind of like pulling the plug on your computer at home.
Niteshade
Jul 25, 2013 09:57 PM
mbarnes1982
Apr 3, 2008 09:37 PM
ajluu
Jan 3, 2008 12:51 PM
BLuEPiTBuLLz
Jul 15, 2007 04:28 PM
zoominhuman
Mar 30, 2007 06:55 PM
