P1457 code correction. Location of canister?
Old Apr 3, 2008 | 03:15 PM
mbarnes1982
Default P1457 code correction. Location of canister?
My 1998 Accord DX 2.3L VTEC; I had a P1457 code "EVAP Emissions System" "Control Canister System". I have found from other threads that often salt used in winter storms can cause corrosion in the purge valve and solenoid. It sounds silly, but I cannot find the vapor canister! Any ideas?
Also, I am just beginning to build this car and am starting with suspension/brakes. I am only installing parts that are high quality/functional. No "rice boy" crap! Input appreciated on suspension. Brembo brakes is what I am leaning toward currently.
Old Apr 3, 2008 | 04:02 PM
Default RE: P1457 code correction. Location of canister?
On the firewall on the passenger side below fuse box.
Old Apr 3, 2008 | 04:49 PM
deserthonda's Avatar
what i have founf going bad for code p1457,, is the evap 2 way valve and the evap bypass solenoid valve ,, located by the fuel tank.. BUT i live in AZ no rust here ,, you might want to have it properly diagnosed before you start replacing components
Old Apr 3, 2008 | 04:53 PM
In '98 the canister is located underneath the car, justforward of the gas tank. Roughly below theleft-rear seat.
Purge valve is in the engine compartment, but the common failure seems to be the canister vent-shut valve. That one's located on the outboard end of the canister, rather close to the left rocker panel & rearjacking point.
Old Apr 3, 2008 | 04:57 PM
mbarnes1982
Thank you gentleman! This is an awesome Forum! Just found it today! Wonderful!!!
Old Apr 3, 2008 | 04:59 PM
Make surethe C-V-S valve isactually broken before spending $50 on a new one...
Old Apr 3, 2008 | 07:33 PM
Chiovnidca's Avatar
ORIGINAL: JimBlake
Road salt gets in em and eats them up. That's why DH doesn't see many, they dont use much salt in arizona.
Bypass and 2-way valves are getting a lot more common than they were a couple years ago.
X2 Dont throw parts at it. Diagnose, then repair.
Old Apr 3, 2008 | 07:55 PM
mbarnes1982
So to test the components... apply 12V to the solenoid to check for action, and about the mechanical valves? How do I actuate them, with a vacuum pump?
Old Apr 3, 2008 | 08:09 PM
Yeah, apply 12v & check that the valve changes state. I forget which ones are normall-open or normally-closed.
When my C-V-S valve failed, it didn't even clickwith 12v.
Old Apr 3, 2008 | 09:37 PM
More checks...
Be sure to check the circuits,in case the valve is OK but a wire is broken; you get the idea...
For each of those solenoidvalves, one wire should have battery voltage from the main relay. It's ON all the time as long as the car is on.
The other wire goes to the ECU which closes the circuit to ground when it wants to energize the valve.
JimBlake
DIY Answers.
Aug 6, 2009 01:36 PM
benjiaccord
Oct 27, 2008 09:34 AM
accords own
Sep 17, 2008 08:23 PM
ajluu
Jan 3, 2008 12:51 PM
zoominhuman
Mar 30, 2007 06:55 PM
