Parasitic Battery Drain 08 Accord
Old Apr 27, 2021 | 05:19 PM
brittneydalton5@hotmail.com's Avatar
Default Parasitic Battery Drain 08 Accord
I’m at a loss trying to fix this car. We’ve switched out the starter and ignition switch. It is an 2008 Honda Accord. Had it tested at a auto zone and they said they think it’s a parasitic drain on my battery. As much as I’d love to drop 80-100 an hour to find the issue, I’d rather not. Right now, my car starts strong for about a week, week and a half, then the following week the starts get weaker, until a cold night and my car won’t start at all. When the car is turned off, no key, the radio will sometimes switch on. But today after a friend tested my alternator, the clock isn’t on when I turn off my car and it hasn’t switched back on. Should I just disconnect the radio and call it a day? Auto zone did also mention maybe it was a tension belt as well
Old Apr 27, 2021 | 05:42 PM
That is a tough call on what to do. You should test to narrow down the component(s) drawing current.
If you have a volt meter that can read current, then we can give you some directions how to identify the problem.
Old Apr 28, 2021 | 06:06 PM
UhOh's Avatar
Originally Posted by brittneydalton5@hotmail.com
I’m at a loss trying to fix ... Should I just disconnect the radio and ...?
Do the test. Disconnect the radio and see if it solves the problem over this next month.
JimB4
Nov 19, 2011 12:10 PM
Tazman282
Jun 15, 2011 06:34 PM
SteW
Sep 7, 2010 02:29 PM
fortyfootelf
Feb 18, 2010 11:44 AM
