Part number for Idle Air Control Valve fastener?
Old Aug 7, 2011 | 12:30 AM
MessAround's Avatar
Almost A Senior Member
Default Part number for Idle Air Control Valve fastener?
I'm having a devil of a time removing the IACV. By that I mean I can't remove it at all.
I'm afraid I'm going to break the bolts taking this thing off. I've used PB Blaster like four times. The bolts won't budge. I'm thinking it might break so I'm trying to find out if parts websites even sell a Honda replacement for these bolts in case I have to drill them out.
This is so troublesome I may not even clean the IACV. Much less hassle not even bothering if I'm risking breaking the bolt.
Old Aug 7, 2011 | 12:48 AM
piggylover1985's Avatar
Check this out to see if it helps Part Detail
Old Aug 7, 2011 | 01:12 AM
MessAround's Avatar
Thanks! I don't know why I couldn't find it. I was looking at Intake Manifold. There it is though, pretty cheap too.
Thanks again!
Old Aug 7, 2011 | 05:44 AM
Were here to help out each other :-)
Old Aug 7, 2011 | 07:55 AM
If you have a breaker bar, use that to break the bolt loose. Avoid rounding the bolt head w/ an open-end wrench. If already rounded, Craftsman makes a "damaged bolt removal socket set" that will grab a damaged bolt head.
Old Aug 7, 2011 | 01:12 PM
MessAround's Avatar
Yeah but wouldn't a breaker bar still break a bolt head off of the body of the bolt if the threads are holding the bolt on tight? I know a breaker bar applies more torque but I thought that just meant a stuck bolt would have its head broken off faster.
Old Aug 7, 2011 | 01:35 PM
If a bolt fails due to torsional shearing, it will fail at the top of the threads (smallest cross-section).
If it twists off, you will need to remove the throttle body and go to a machine shop for bolt removal and perhaps thread replacement.
I think it unlikely you will twist the bolt off, but can't be sure.
You might try heating w/ a propane torch to help removal.
Old Aug 7, 2011 | 03:02 PM
Just try not to catch the car on fire with the propane torch :-)
Deviatorz
Jun 5, 2014 10:03 PM
anubyss
Jul 22, 2013 10:37 AM
lz7478
Jan 14, 2013 03:59 PM
Brash
Jun 24, 2012 04:26 AM
autobot_78
Sep 27, 2010 06:48 PM
