passenger window won't roll up from driverside
Old Jun 12, 2011 | 12:17 AM
crvone's Avatar
Default passenger window won't roll up from driverside
On my 95 Accord I can roll down the front passenger window from the switch on the driver door, but when I press the switch to roll it up nothing happens (silence). The switch on the passneger door works fine (it lowers and raises the window).
Anybodey have similar problem, what was the fix?.. thanks in advance.
Old Jun 12, 2011 | 02:21 AM
The first thing I would do is put something like a light coating of silicone paste in the run channel to see if the channel is binding the motor.
Old Jun 12, 2011 | 07:02 AM
piggylover1985's Avatar
The master switch could be bad.
Old Jun 13, 2011 | 11:45 AM
draser's Avatar
Pass window switch, driver side? Try to get the switch loose, and check w/test light/meter if 12V gets out when you try to raise pass window.
djkurious
Sep 2, 2013 03:20 PM
savoiu
Aug 28, 2012 11:12 AM
92tealaccord
Apr 9, 2012 02:25 PM
rubberducky101
Feb 17, 2012 08:03 PM
brave_mhy
Sep 20, 2007 08:55 PM
