Rear Door (driverside) Lock Loud noise
Old Sep 19, 2007 | 08:45 PM
brave_mhy's Avatar
Default Rear Door (driverside) Lock Loud noise
My power door lock still works, however, the driversiderear door lock makes unbelivable, LOUD!!! noise when it opens and closes by my power keypad. The noise comes from exactly the lock latch position, seems to me some gears are worn out (if there is any). I am planning to remove the door panel and look inside and see what is making that noise. Anyone has any comments about this problem, is it common and easily fixed?
Thanks in advance for any input!
Old Sep 19, 2007 | 09:02 PM
nafango2's Avatar
Default RE: Rear Door (driverside) Lock Loud noise
what kind of noise is it?
grinding noise?
Does the lock still work?
Old Sep 20, 2007 | 08:36 PM
brave_mhy's Avatar
Thanks! nafango2, the lock still works, and the sound comeswhen the lock **** pops up and pops back down again (about one second or so each time). It seems to me the sound is like operating the electric drill as if I were drilling a hole on a super hard metal peice! I can hardly believe anything behind the door panel can generate such a loud sound, everyone in the parking lot was looking at me. I guess maybe the gear is not properly engaged with the rack (if there is any, no sure at all), but never worked on the door structure before especially the lock machanism.
Appreciate any comments!
Old Sep 20, 2007 | 08:55 PM
nafango2's Avatar
I had the same problem.
sounds like the actuator is on the verge of breaking down. If you want, you can replace it or try to fix it. Fixing it isnt that hard if you have any mechanical skills.
follow the instructions i posted on this thread: https://www.hondaaccordforum.com/m_7..._/tm.htm#77914
There might be a different problem inside the actuator, like a partially stripped gear but it sounds like its having the same problem only not as severe. when you open up the actuator and plug it in to see the problem, bear in mind it might not be the same as the one i detailed in that thread, but the process for removing the actuator and troubleshooting is the same.
SPD-2000-HONDA-ACCORD
Mar 29, 2013 08:50 AM
Doublel
Mar 11, 2013 07:57 AM
rrhonda
Jun 13, 2011 09:15 PM
crvone
Jun 13, 2011 11:45 AM
cbarron814
Sep 22, 2008 08:03 PM
