PCM swap
Old May 22, 2017 | 07:29 AM
Cavell's Avatar
Default PCM swap
If you replace a pcm you have to reprogram its security key? So your key won't start car unless you do? What would happen if you changed lock cylinder and key from donor car along with Pcm? Would car start? I found seller parting out car with abs controller I need. And all other parts.
Old May 22, 2017 | 08:26 AM
It depends on what year/model of Accord you're talking about.
Old May 22, 2017 | 09:53 AM
Cavell's Avatar
01 accord ex v6
Old May 22, 2017 | 12:12 PM
Pretty sure you can grab the PCM, keys, and ignition-lock cylinder and then you're OK.
For your convenience, you might also want the lock cylinders for the doors & trunk so the new keys can get in the door if your battery dies.
rbrunner
Jul 3, 2017 10:31 AM
jeffk14
Oct 21, 2011 11:32 AM
BruceHunt
Apr 1, 2011 04:58 PM
ufosearch
May 18, 2009 03:10 AM
blazinfnestyle
Mar 19, 2007 06:02 PM
