PLEASE HELP
Old Mar 20, 2008 | 11:12 AM
Jidaisgreat
Default PLEASE HELP
Can someone PLEASE guide me with me query. I am a taxi driver in Uk and drive a 2001 Honda Accord SE Vtec. I took my car for check up te get new taxi plates to keep on working, and they told me to get two things repaired before i can work again. the item are :
Off Side Front Anti Roll Bar Link and
Off Side Front Stabilisr Arm Bush.
I honestly havnt got a clue what these parts are and dont want to waste money buying wrong parts. Can someone PLEASE PLEASE guide me or show me what I am suppose to buy.Please reply ASAP as its my livelihood.
Thank You and Kind Regards
Old Mar 20, 2008 | 11:25 AM
sir_nasty's Avatar
Default RE: PLEASE HELP
give me a moment.... I'm going to hondaautopartswarehouse.com for their diagrams... in the meantime go to our DIY section and find the download for a free manual...
Old Mar 20, 2008 | 11:34 AM
sir_nasty's Avatar
Based on your description to the best of my knowledge (granted I'm from the U.S.) the two parts in bold are what they are talking about... Confirm this from the diagram before you do anything (diagaram is of the passenger side sway bar end) also that stuff below is from hondapartswarehouse.com but you can find that stuff anywhere, just call a local honda dealership and confirm this stuff.
001 51300-S84-A01 1 SPRING (26.5MMXT4.5) $49.70 $43.84 Qty: 001 51300-S84-A32 1 SPRING (24.2MMXT3.0) $53.00 $46.75 Qty: 002 51306-S84-A01 2 BUSH (26.5MM) $2.78 $2.45 Qty: 002 51306-S84-A32 2 BUSH (24.2MM) $3.93 $3.47 Qty: 003 51308-SW3-000 2 BRKT, FR. STABILIZER $6.85 $6.04 Qty: 004 51320-S84-A01 1 LINK, R. FR. $26.45 $23.33 Qty: 005 51321-S84-A01 1 LINK, L. FR. $26.45 $23.33 Qty: 006 51352-S84-A01 1 ROD, R. FR. RADIUS $48.80 $43.04 Qty: 007 51355-S84-A00 1 ARM, R. FR. (LOWER) $163.45 $144.16 Qty: 008 51362-S84-A01 1 ROD, FR. RADIUS $48.80 $43.04 Qty: 009 51365-S84-A00 1 ARM, L. FR. (LOWER) $163.45 $144.16 Qty: 010 51381-S84-A01 2 BUSH, FR. RADIUS ROD $2.92 $2.57 Qty: 011 51391-S84-A01 2 BUSH, RADIUS ROD $2.98 $2.63 Qty: 012 51393-SV1-A01 2 BUSH, FR. STABILIZER $6.40 $5.64 Qty: 013 51394-S84-000 2 WASHER $3.90 $3.44 Qty: 014 51398-SM4-000 2 COLLAR, RADIUS ROD $5.13 $4.53 Qty: 015 51399-S0A-000 4 WASHER, FR. $5.13 $4.53 Qty: 016 51810-SV4-003 2 BUSH, SHOCK ABSORBER $18.57 $16.38 Qty: 017 51811-S84-A00 1 FORK, R. FR. FORK $59.40 $52.39 Qty: 018 51821-S84-A00 1 FORK, L. FR. FORK $59.40 $52.39 Qty: 019 74180-S84-A00 1 BAR, R. FR. STRUT $34.67 $30.58 Qty: 020 74185-S84-A00 1 BAR, L. FR. STRUT [b][color="#006
Old Mar 20, 2008 | 12:44 PM
oma93's Avatar
FWIW if you are replacing these on one side you might as well replace them on both. The mount bushings come as a pair so you would only need to buy one more end link set, about $14USD. labor can't be tha much as this entire job is about20 minutes.
Old Mar 20, 2008 | 01:42 PM
Jidaisgreat
Thank you all those who have tried to guide me and i appreciate,I am beginnng now to see some light i now know what an anti roll bar link is but no idea about the Stabilizer arm bush, iwent to the examiner who failed my car and he showed me a big rubber bung facing directly at the front of the car and was inside the part called stabilizer arm it was a big rubber bung that needs changing he said and not the whole metal arm.
Regards
Old Mar 20, 2008 | 07:34 PM
I did this job years ago on a 90 Accord and found that it was necessary to have both sides of sway bar loose while starting the nuts on the new sway bar-knuckle bushings. Once both sides are started, tighten both sides. The sway bar guide bushings (on front) should be installed first.
esan805
Mar 29, 2012 02:33 PM
art vandelay
Aug 2, 2010 09:29 AM
mamtsberg
Mar 17, 2010 09:15 PM
BIGWILBO
Apr 5, 2008 07:57 PM
ryan ortego
May 19, 2005 06:06 PM
