Please Help
Old Mar 15, 2013 | 06:19 PM
lost's Avatar
Default Please Help
I have a 2000 model honda accord lx 2.3 liter vtec 4 cylinder, the car runs great but has one problem that I can not figure out. The car will not rev past 3000 rpm no matter what driving it or if it is idleing. If anyone could give me any idea's what it could be I would really appreciate it.
Old Mar 15, 2013 | 06:37 PM
j_sparx88's Avatar
It could be the vehicle speed sensor. If its telling the computer that your going faster than you really are, then that will screw with it. Really need a little more info though. Any other problems???
Old Mar 15, 2013 | 06:55 PM
Is your Check Engine Light on?
It probably is due to something else, not the vehicle speed sensor. The tachometer drive circuit receives pulses from the PCM or ECM. The solid-state tachometer then displays these pulses as engine speed. For each 200 pulses per minute from the PCM or ECM the tachometer displays 100 RPM.
The speedometer drive circuits receive pulses from the vehicle speed sensor; whereas, the tachometer receives pulses from the PCM or ECM.
Old Mar 18, 2013 | 01:24 PM
lost's Avatar
no not really any other problems other than transmission problems it slips and doesnt change gears the way it should and yes the engine light is on.
Old Mar 18, 2013 | 01:55 PM
Your first step should always be figuring out why the check engine light is on. Bring it to a autozone type place and they will read it for free. Make sure you get the actual code not just the employees description of what's wrong then report back to us.
Old Mar 22, 2013 | 07:53 AM
lost's Avatar
I did do that and it came back that it was the camshaft position sensor but when i went to the honda dealer they said that model didn't have this sensor so I am not sure what to do.
Old Mar 22, 2013 | 11:14 AM
... Make sure you get the actual code not just the employees description of what's wrong then report back to us.
The code number would help.
esan805
Mar 29, 2012 02:33 PM
art vandelay
Aug 2, 2010 09:29 AM
mamtsberg
Mar 17, 2010 09:15 PM
BIGWILBO
Apr 5, 2008 07:57 PM
ryan ortego
May 19, 2005 06:06 PM
