Please help
I just recently purchased an 08 Accord V6 for my son. Beautiful, 100k mike car. It started missing and code read cyl 3 misfire. Changed plugs and replaced coil on said cylinder. Still random missing. Pulled out all plugs and inspected for a oil , and or irregular burn. Nothing notable found. Performed a compression test. All cylinders at 190 to 200 psi. Re-install plugs and coil, still missing. On all the forums I read about the VCM issues. I don’t believe this is the VCM doing this, for it does it on a cold as well as warm engine. If it were the VCM woes, I would muzzle it, There is a strange thing it does between 1500 and 2000 RPM under very light acceleration. It kind of has a Shudder, and I can watch the tach needle jump up and down a few hundred RPM. Under heavy acceleration, the car is a beast, the issues are all between 1500 and 3000 rpm. Has anyone else experienced this? I’m not in a position to keep taking it to a dealer, and I am well-equipped to figure out most problems, I just need steered in the correct direction. My wife has owned an Odyssey, and is on her third pilot, no issues thus far. I just can’t see what the issue is here, I love the Accord, But I’m losing more hair by the day over this.
This sounds like my daughter in laws Pilot, in that it gets a misfire, then turns on the check engine light. She's taken it to the dealer 4 times now, and no code coughs up, so they clear the codes and turn off the CEL light. Then it runs fine for a few months or 6 months or so then it does it again. The dealer can't find the problem with it either.
art vandelay
Aug 2, 2010 09:29 AM
ryan ortego
May 19, 2005 06:06 PM
