Plug wires
Old Jul 3, 2009 | 12:52 AM
bigdawg74's Avatar
Default Plug wires
Doing a tune-up on the 2002 and bought some "Duralast" wires @ Autozone and the darn things are about 1/4" too short. Won't stay on the plugs in the chamber. So after I return them I am looking at getting a different brand. I know most folks don't like Bosch plugs, but what about their wire sets? Amazon has those, or a set of Denso OE wires for pretty good price (about $40). Any recommendations? Thanks, everyone.
Old Jul 4, 2009 | 07:09 AM
fusionstar's Avatar
Denso or NGK or OEM
Old Jul 4, 2009 | 08:01 AM
falkore24's Avatar
^^^ he's right. Denso or NGK ARE OEM and hondas don't like anything else for ignition parts.
Old Jul 4, 2009 | 12:49 PM
bigdawg74's Avatar
Falklore: I put NGK single platimum plugs in, and put the old factory wires back on. The cap/rotor are the AutoZone brand. It runs pretty good, not that it ran "bad" before. Any harm being done buy using the old wires? I have about 82k miles on it.
Old Jul 5, 2009 | 03:34 AM
falkore24's Avatar
Theres probably no problem with the old wires, but you should check them at night with a spray bottle. With the car running, spray a mist over the wires to see if they ground on the engine. If you get a little light show, then you need new wires.
Old Jul 5, 2009 | 07:46 AM
daniel86
Great questions and answers.
Old Jul 6, 2009 | 07:08 AM
In complete darkness.
If the insulation of the plug wires is breaking down, they might show a blue glow but you probably won't see that in the daytime.
Factory plug wires can last a long time. My 95 Integra factory wires were good when I sold the car after 10 years & 130k miles. I just clean them with soap & water whenever I change oil.
Old Jul 6, 2009 | 07:52 AM
bigdawg74's Avatar
I will try that tonight when it gets dark. There's no performance related issues to make me suspect that they are going bad, but they just looked kinda "tired" when I replaced the plugs. The boots inside the plug cylinder had some brownish-white deposits on them, at least on two of them. But they run fine. I suppose they could use a quick cleaning.
Old Jul 6, 2009 | 09:49 AM
00AccordLX5spd's Avatar
Registered User
OEM plug wires are Sumomito (could have spelled this wrong), not NGK.
Old Jul 7, 2009 | 01:03 AM
bigdawg74's Avatar
Default Update
Sprayed the wires, no lightshow, so I guess they are all good. Thanx for the help.
wannakeepmy94Accord
Mar 14, 2012 08:06 PM
Calevra18
Sep 16, 2007 10:45 PM
jrcastro
Jun 10, 2006 05:32 AM
deserthonda
May 29, 2006 03:28 PM
deserthonda
May 12, 2006 03:14 AM
