possible head gasket on 94 accord help!!
Old Jul 24, 2007 | 09:40 PM
toddyfresh's Avatar
Default possible head gasket on 94 accord help!!
my g/f 94 accordhas been acting weird maybe a head gasket. its been sittin for a while. he has had problems so i went to check it out here is what i got. after sittin about 2 weeks since being started we started it no problem checked it out. no water leaking that i saw, but she did say she had temp problems goin up a little more than usual. we drove it around for like 5 minutes and had it idled inmy driveway for about 45 minutes and a/c on. Temp never went past half way. we shut it off and start a few times ok. it didnt seem to have the power it should so i shut it off for like the third time to check some stuff. I tried to start it up and it made like a squeaking sound and blew enormous amount of white smoke out of it and it barely started and when did it acted like it was on like 1 cylinder and stalled and wouldnt start no more. sound like a headgasket to you or maybe crack in block but i didnt see no water leak
Old Jul 24, 2007 | 10:04 PM
hondadude's Avatar
Default RE: possible head gasket on 94 accord help!!
you might want to remove a spark plug or 4 and use a strong flashlight to look into the cylinders.
any coolant loss in the level of the radator?
if you leave the radiator cap off and start the engine does coolant spew out?
You might not be able to diagnose this problem by looking at things.
Old Jul 24, 2007 | 10:56 PM
toddyfresh's Avatar
in the time i had it started i didnt see a coolant leak, the coolant did wanna fly outta radiator when i took cap off like its preesurized as usual?
Old Jul 25, 2007 | 12:51 PM
toddyfresh's Avatar
anything else i should look for?
Old Jul 25, 2007 | 01:57 PM
deserthonda's Avatar
ORIGINAL: toddyfresh
Do a cylinder leak test
bannacrx
Apr 29, 2010 02:10 PM
J_von
Feb 3, 2009 07:18 PM
troy331
Sep 8, 2007 03:20 PM
thunder_x
Jul 9, 2007 11:57 AM
dodins
Mar 18, 2007 08:10 PM
