Need Help changing head gasket
Old Jan 16, 2009 | 07:19 PM
J_von
Default Need Help changing head gasket
Okay so i have a 99 accord ex 2.3L and i need to change the head gasket. Where do i start?
Old Feb 3, 2009 | 07:18 PM
loadder's Avatar
Default start here
remove everthing that is in your way to gain access to the valve cover, remove valve cover, take off timing belt, remove head bolts, lift off head, get a valve job done, buy a gasket set, along with a new timing belt, clean all surfaces where new gasket will touch, apply some gasket sealant, apply gasket, replace head, tighten bolts to specs, replace timing belt and valve cover and all the things you had to move to get to the valve cover, fill with oil and water make sure you set the timing right, new plugs and wires while you are there, and probably a thermostat wouldnt hurt either seeing as you got it hot so hot...referring to a manual wont hurt you at all either
Uryupin
Nov 22, 2012 03:08 PM
crispin
Jun 4, 2012 02:09 PM
toddyfresh
Jul 25, 2007 01:57 PM
thunder_x
Jul 9, 2007 11:57 AM
dodins
Mar 18, 2007 08:10 PM
