Power Mirror Gremlins
Old Jun 23, 2008 | 12:39 PM
chestah cheetah
Default Power Mirror Gremlins
2000 Accord EX Coupe
Newbie here. Wanted to descibe an issue so see if anyone has any insight:
Replaced the drivers side mirror, motor module, and wiring harness. Put everything back together and now the mirror positioning switch on the door panel is only capable of moving the mirror to the left. No up, down, or right functionality. The issue has also spread to the passenger side. Before I installed the new parts, I did "mock up" the new motor module to the old wires and the whole thing worked fine. Anyone have a guess? Thanks.
Old Jun 23, 2008 | 12:55 PM
HondaPhyco's Avatar
Default RE: Power Mirror Gremlins
recheck wires and make sure they are connected right.
Old Jun 23, 2008 | 05:51 PM
chestah cheetah
The new kit came with a new wiring harness with slightly different colors. I wired like this:
Yellow to Yellow
Gray to Gray
Dark Gray to Black
Old Jun 24, 2008 | 10:02 AM
HondaPhyco's Avatar
wierd but i would try switching the dark grey and blak just tosee the out come you never know. but wit aftermarket stuff it never matches up to factory perfectly.
Old Jun 24, 2008 | 11:48 AM
falkore24's Avatar
If it all worked properly before you put everything back together, then you pulled on a wie when you were reassembling the door. Check the wires again.
mynthia
Nov 7, 2013 05:32 PM
my97hondase4banger
May 28, 2010 05:33 PM
jwa074
Jun 16, 2009 07:22 AM
maro
Jun 4, 2009 08:35 AM
dsgammo
Sep 11, 2007 05:24 PM
