Power seat problem on 97 Accord EX
When I first push power seat switch lever to move seat forward it only moves a little (varies about a couple of inches) and stops. Then must wait about 5- minutes (varies more or less) then it moves the rest of the way when I push lever again. It’s intermittent and varies a lot in the time I have to wait and if it works all the way the first, second or third time.
The rails era clean lubed and clear, no obstructions. I took the operating switch/lever apart and it was fine but cleaned and lubed contacts anyway. So it is not any obstruction or the switch. Also no fuses cause it works sometimes all the way.
I suspect a relay or the motor. Any suggestions? Anyone has had this problem? HELP PLEASE! It’s driving me knotts!
I used test diagrams that RedBull-1 provided Saturday. The switch and wiring harness tested fine. The motor cable connector housing has external test contacts on the opposite side of the cable connector. So I put the volt meter on these and when you slide the switch forward or backwards it is getting the correct voltage at the motor but the motor does not work. So obviously it is a bad motor.
I took the motor apart, clean the brushes and armature (had a little grease on them) lube bushings and shaft ends, assemble it back and it is as bad or worst now.
Looks to me that bushings are worn out and armature is touching magnet housing or it is just a bad motor.
Any idea where I can get a motor other than the Junker?
JOE.G
Nov 4, 2012 08:48 AM
MysticBlueEX
Feb 18, 2011 06:55 AM
