Power seat problem on 97 Accord EX
Old Jul 6, 2012 | 11:31 AM
tonycolo's Avatar
Question Power seat problem on 97 Accord EX
When I first push power seat switch lever to move seat forward it only moves a little (varies about a couple of inches) and stops. Then must wait about 5- minutes (varies more or less) then it moves the rest of the way when I push lever again. It’s intermittent and varies a lot in the time I have to wait and if it works all the way the first, second or third time.
The rails era clean lubed and clear, no obstructions. I took the operating switch/lever apart and it was fine but cleaned and lubed contacts anyway. So it is not any obstruction or the switch. Also no fuses cause it works sometimes all the way.
I suspect a relay or the motor. Any suggestions? Anyone has had this problem? HELP PLEASE! It’s driving me knotts!
Old Jul 6, 2012 | 06:29 PM
Is the problem only when sliding forward/backwards? Or does the seat have problems with recline and other functions?
Old Jul 7, 2012 | 08:40 AM
tonycolo's Avatar
The problem is only when sliding forward/back. All other functions work fine. Up/down tilt & recline work fine.
Thanks asking PA honda.
Old Jul 7, 2012 | 09:25 AM
Sounds like a motor problem. There is no relay in the 6-way power seat circuit.
You can test the switch and motor (see attached pics.); but, it sounds like the motor needs replacement.
Attached Thumbnails Power seat problem on 97 Accord EX-6-way-power-seat.jpg   Power seat problem on 97 Accord EX-6-way-power-seat-circuit.jpg   Power seat problem on 97 Accord EX-switch-motor-test.jpg
Old Jul 9, 2012 | 08:19 AM
tonycolo's Avatar
Thank you RedBull-1. I will use test diagrams and test next Saturday. will update after testing.
Old Jul 16, 2012 | 07:45 AM
tonycolo's Avatar
Default Power seat problem on 97 Accord EX
I used test diagrams that RedBull-1 provided Saturday. The switch and wiring harness tested fine. The motor cable connector housing has external test contacts on the opposite side of the cable connector. So I put the volt meter on these and when you slide the switch forward or backwards it is getting the correct voltage at the motor but the motor does not work. So obviously it is a bad motor.
I took the motor apart, clean the brushes and armature (had a little grease on them) lube bushings and shaft ends, assemble it back and it is as bad or worst now.
Looks to me that bushings are worn out and armature is touching magnet housing or it is just a bad motor.
Any idea where I can get a motor other than the Junker?
Old Jul 16, 2012 | 05:49 PM
A "junker" is prob going to be the cheapest option.
Thry places like car-part dot com and see what is around you locally.
Old Jul 17, 2012 | 02:28 PM
tonycolo's Avatar
Thanks Poorman212.
I will try to take it apart and fix it one more time and if I can’t then will look into car-part.com or Junkers.
Capio
Jul 11, 2014 03:18 PM
JOE.G
Nov 4, 2012 08:48 AM
rah140
Jul 4, 2012 06:17 PM
MysticBlueEX
Feb 18, 2011 06:55 AM
lacrw
Aug 1, 2007 08:43 AM
