Power Steering Leak
Old Nov 8, 2012 | 08:13 AM
Jamar.stroud's Avatar
Default Power Steering Leak
We have a 2008 Accord EX-L with the 190-hp engine. It leaks power steering fluid on a constant basis, to the point that every 2 weeks, the reservoir is at half. I took it to the dealer's service department to get it looked it and they advise that its leaking from the rack and pinion. They also advised that is would cost apprx. $1200 for fix.
Being that we have a 7mo old, we dont really have that much money laying around :-) so my question is, is this is must fix issue or will it be ok to just continue filling the reservoir every coupe weeks for a while.
Old Nov 8, 2012 | 11:19 AM
Roader's Avatar
It's OK to keep filling the reservoir but don't let it get below the MIN mark.
I've had good luck with Lucas power steering stop leak. It completely stopped a much smaller rack leak than yours. Have been using Autozone's brand of PS fluid labeled for use in Hondas with good luck too.
Old Nov 8, 2012 | 11:38 AM
Agree that Lucas PS Seal fluiid is worth a try. My father fixed a Toyota Avalon Rack w/ this.
Try O'Rielly's MasterPro PS fluid. $5.50/qt is a bargain and it's Honda/Acura compatible. I've used w/o problems.
Old Nov 8, 2012 | 01:41 PM
Thank you! I will let you know the results of the leak stop.
Old Nov 10, 2012 | 01:08 AM
UhOh's Avatar
Son has '86 prelude that has been on life support for 4 years.
He checks PS fluid reservoir every month and adds. Prior owner did same.
Old Nov 12, 2012 | 01:07 AM
darkgreen18290's Avatar
have same issue with my PS, i just keep on adding fresh honda PS fluid every other week. the leak is not that heavy thou. have used PS stop leak sometime back (forgot the brand name) but it didn't work at all.
Old Mar 2, 2013 | 07:19 AM
Ed4ward1982's Avatar
Any good news?
darkgreen18290
Jun 25, 2013 07:51 AM
Johnene
Aug 24, 2010 06:59 AM
quique304
Feb 12, 2008 12:19 PM
Hondaccord
Dec 17, 2006 04:58 PM
CRWJumper
Apr 13, 2006 11:54 PM
