Power steering leak
Old Sep 2, 2014 | 02:22 AM
LCSar's Avatar
Default Power steering leak
New to the forum. So here it goes, change my serpintine belt. 08 accord 3.5 V6 auto tran., the power steering fluid starts to leak soon I start the car. Seems there's a clog or the pump is pumping the wrong way. I can see bubbles of fluids coming up the reservoir. What do I do.
Old Sep 3, 2014 | 05:14 PM
Please don't put your email in clear text - that's a spam magnet. People can email you by clicking your username.
So are you really sure you have the new belt installed correctly? Maybe the pump IS ACTUALLY spinning backwards?
Old Sep 4, 2014 | 07:58 AM
LCSar's Avatar
Yes I followed the layout, serpentine belt is correct
Old Sep 4, 2014 | 05:16 PM
Check for a leak at the low-pressure hose at the pump. That's the line from the bottom of the PS fluid reservoir directly to the pump. Air sucked in there would make foam in the fluid, causing overflow.
Dirty PS fluid reservoir? I think there's a fine mesh screen submerged in the fluid. If that's dirty, then the pump is pulling a stronger vacuum in that line.
Old Sep 5, 2014 | 12:08 AM
WheelBroker1's Avatar
Welcome to the forum and I moved you to this forum for more answers..
Old Sep 6, 2014 | 05:53 PM
Bange's Avatar
Take off the lines on the pump, it's probaly just the o rings are worn down, replace the o rings with oversized new ones and see if it stops leaking.
darkgreen18290
Jun 25, 2013 07:51 AM
Johnene
Aug 24, 2010 06:59 AM
quique304
Feb 12, 2008 12:19 PM
Hondaccord
Dec 17, 2006 04:58 PM
CRWJumper
Apr 13, 2006 11:54 PM
