Power Steering Leak
Old Oct 19, 2015 | 08:40 AM
rockhoundrob's Avatar
Default Power Steering Leak
1998 Accord LX 4 Cyl automatic - 185,000 miles
There is a small leak in a hose near the bottom of the radiator. It is part of the power steering line. I plan to replace the 3 rubber hoses and the power steering reservoir. When I remove these hoses, can I get an air hose and blow out the power steering fluid that goes to the pinion rack? I just want to replace the fluid while I am at it. If not, is is OK to just add new fluid and then it is about 25% old and 75% new?
Old Oct 21, 2015 | 07:37 PM
My opinion, replacing the lost fluid with new Honda/Acura approved fluid will be fine.
For me when the PS fluid is due, I just remove the reservoir and dump the fluid in it. Clean it with the proper cleaner and then refill with fresh Honda/Acura PS fluid.
Old Oct 22, 2015 | 07:57 AM
Sounds good! Will do that....
Old Oct 27, 2015 | 08:46 AM
brocko's Avatar
You can flush new fluid thru it. Take off the return hose at the pump. Remove the efi fuse. Point the return hose into a drain pan. Fill the reservoir and keep it filled. Crank the engine incrementally until clean fluid comes out the return hose.
I like to add a clear tube to the return hose to extend it into the drain pan. You can get em at Home Depot. Just tell em you want to make a beer bong and they'll know where to look. Use the honda ps fluid. I think I needed 2 pint bottles...
Old Oct 28, 2015 | 08:07 AM
Already done. Thanks for the input!
darkgreen18290
Jun 25, 2013 07:51 AM
Johnene
Aug 24, 2010 06:59 AM
quique304
Feb 12, 2008 12:19 PM
Hondaccord
Dec 17, 2006 04:58 PM
CRWJumper
Apr 13, 2006 11:54 PM
