power steering reservoir back flow
Old Jan 9, 2014 | 12:12 AM
BigmoneyG's Avatar
Default power steering reservoir back flow
I've recently noticed a whining noise which appears to be coming from the ps pump, followed by the ps fluid backing up through the plastic reservoir bottle. Both stop after about 30 secs. I was told by my mechanic friend that it may have air somewhere in the ps system. Does this sound plausible and is there a way to bleed the system? Also, the fluid that seeps out doesn't appear normal, it is bubbly when it comes out.
Old Jan 9, 2014 | 12:17 AM
We will have to get some research done on this..in the meantime..use our search link up top to see if you find it in a post by another member..
Welcome to the HAF..
Old Jan 9, 2014 | 08:39 AM
What Year/trim Accord do you have?
Usual problem is air getting into PS fluid w/ cold engine causing whining and growling when steering is used.
On V6's there is an oring on the PS pump suction inlet fitting that is usual cause of air entering system.
Note, air is circulated out w/ PS operation, so if air stops entering (when fluid is warmed), the fluid will appear normal. No air is permanently retained.
PGRNPA
Sep 29, 2013 09:30 AM
divinations
May 31, 2013 07:52 PM
MessAround
Nov 4, 2012 06:51 PM
inthedump
Oct 28, 2009 09:35 PM
iridebmx33
Nov 26, 2007 06:53 PM
