pressure bleed brakes?
Old May 19, 2007 | 06:16 PM
dexter1's Avatar
Default pressure bleed brakes?
I recently purchased a 1990 Accord EX and replaced the master cylinder withiut bench bleeding it first. I know! If I have the system pressue bled, will that get the air out of the master? Thanks for your help.
Old May 19, 2007 | 10:14 PM
Default RE: pressure bleed brakes?
Pressure bleeding is good, but any type ofbleeding will work if you are careful. I use the traditional, pump & bleed, which is a form of pressure bleeding. If you mean forcing fluid from the reservoir w/ a pressure cap and pump, this is a good method if you have the equipment, but is not essential.
Suction bleeding suffers from tendency for air to enter around suction connection to bleeder or around the bleeder threads themselves. Still, w/ care you can bleed the brakes using suction bleeding also.
Old May 20, 2007 | 08:49 AM
deserthonda's Avatar
if it takes a lont time and pedal does not respond you need to bleed it first at the brake master by loosening up the 2 lines going into the brake master cylinder
eduard
May 9, 2013 12:11 AM
HondaWoman
Jul 25, 2012 08:02 PM
piconrule
Jul 24, 2009 02:38 PM
ModestMitch
Apr 18, 2008 11:05 AM
meazz1
Feb 4, 2006 07:56 PM
