Problem Bleeding Brakes...
Old Aug 9, 2008 | 07:31 PM
corr04's Avatar
Default Problem Bleeding Brakes...
My 96 Accord lx 5 sp. needs the brakes bled. The problem is I broke off the left rear bleed screw trying to loosen it. None of it is sticking out so I cant get a grip on it what so ever.
Is it possible to loosen the brake hose/nut that goes into the back of the hub and bleed it that way? I have tried a few times with no sucess.
Or does anyone have any tips on removing the broken bleed screw? Any help is much appreciated. Thanks in advance!
-corr04
Old Aug 9, 2008 | 07:53 PM
Default RE: Problem Bleeding Brakes...
You will not be able to bleed by removing the hose from the back of the caliper. Go to parts store and get a new bleeder valve.
An easy-out should get that out.
deserthonda
Mar 30, 2013 01:11 AM
Pajamarama
Sep 1, 2012 03:21 PM
Gameboy_63
May 16, 2008 03:59 PM
nmikmik
Dec 1, 2007 11:14 AM
BlueByYou
Oct 8, 2006 01:43 AM
