Proper way to recharge AC?
Old Jun 17, 2006 | 06:33 PM
Dshow's Avatar
Default Proper way to recharge AC?
I recently purchased a '94 Accord LX. The AC has been dead since I bought it and the compressor would not engage. I noticed on the wiring diagram that there is a pressure switch that shuts off the compressor when there is 0 pressure. I tried to recharge the system, but since the compressor was not turning, the pressure switch would not close. To get around this, I shorted the contacts across the relay to the compressor so it would engage. I recharged the system with the compressor running and that allowed the pressure switch to close. I put everything back to normal and everything works as it should.
My question is, is there an easier or better way to recharge a totally dead system without shorting across the relay? Will pressure build up in time without the compressor?
Thanks!
Old Jun 17, 2006 | 10:31 PM
YeuEmMaiMai's Avatar
Default RE: Proper way to recharge AC?
get the leak repaired.
evacuate the system
place on vaccum for at yeast 4 hours
recharge
Old Jun 18, 2006 | 04:48 AM
deserthonda's Avatar
ORIGINAL: Dshow
Thanks!
if you had to jump the realy to get compressor to come on,, there is an electrical issue with the a/c system,, could be a bad relay,
if the system was totally empty, by recharging system, a/c compressor should come on, if all components are ok..
by jumping the relay,, it could be a bad relay, or a bad power or ground on the other side of the relay thus not energizing the relay to get power through to compressor ..
i am assuming you jumped the white wire and the red wires together.........
this is what you do.. chk fuse # 8 , underdash fuse box ,, 7.5 amps.. if fuse is ok.. go to the compressor relay and chk for power at wire black./ yellow .. and white wires with key on, you should have power at both,, also chk for a ground at red/blue wire.. ,, if you get all of those and when you jumped the white and red wires compressor came on,,
the compressor relay is no good,,,,,,install a new relay and retry ..
chk these and post the results ..
Now if the system was empty , there could be a leak, add some a/c dye into the a/c system , then with an ultra-violet light you can chk for leaks .. sometimes if the leak is small it might take a few days before leak will show .. I have seen a lot of DICHARGE hoses leaking ..
let me know the results ..
Old Jun 18, 2006 | 01:05 PM
Dshow's Avatar
Thanks for all the responses.
Basically, the system has been working fine for 3-4 weeks now. Once I jumped the compressor relay to get it running while recharging the system, it built up enough pressure to close the pressure switch and I could remove my jumper. The compressor now comes on when it's supposed to.
What I was wondering was if there a better way (or correct way) to build up pressure in the system without jumping the compressor relay....
Thanks-
Old Jun 18, 2006 | 07:35 PM
AgentofDarkness's Avatar
Nevermind, i gotta remember to read all the posts...
piper09
Jul 21, 2009 04:18 PM
nsx
Mar 26, 2008 10:23 AM
MALSR
Apr 30, 2007 01:00 AM
00AccordLX5spd
Apr 16, 2007 12:18 PM
2007accord
Feb 14, 2007 12:57 AM
