Pulling Distributor
Old Aug 30, 2006 | 07:22 PM
Ujhonda
Default Pulling Distributor
I need to remove the distributor for the purpose of replacing the o-ring on its shaft. Can I just pull it out, after marking the correct positions of the rotor and the housing or do I need to turn the engine first to DTC for cylinder No. 1?
1992 Honda Accord manual, 2.2
Please advise.
Old Aug 31, 2006 | 01:55 AM
Default RE: Pulling Distributor
No need to mark the rotor. Only mark the position of the distributor base where it mounts against the head. The mounting bolts are slotted so you can twist the distributor to adjust the spark timing.
The actual spinning shaft inside can only fit one way. There's a blade that's off-center that fits nicely when it's correct. If you get it backwards it won't fit nice & you'll need to force it in. That's your clue that it's wrong...
The BEST way is to get a timing light & adjust the spark timing properly after you put the distributor back on.
najeezy
May 4, 2009 11:45 AM
thunder_x
Aug 26, 2008 07:01 PM
Redcap
May 11, 2008 04:33 PM
PilsMan
Oct 1, 2007 11:06 AM
97LX
Jun 11, 2007 09:03 PM
