Questions about 100k service recommended by mechanic
Old Jan 2, 2016 | 05:40 AM
UhOh's Avatar
Here's my list:
-Timing belt and everything that's involved/included (I'd ask for fresh coolant vs. re-use of your current stuff).
-ATF drain / refill per Blake below. You'll have to do it twice to get a 55% fresh content level. When I bought my used '97, on day one I did two drain and fills separated by 5 miles of driving. Since then I do an annual AT drain/refill in spring (not the 30K interval); takes 2.5 qts for my year.
-Brake fluid flush at your car's age and Ohio's humid atmosphere - yes. Have your brake pads / drums inspected for good life remaining.
-Ignition stuff - no
-Price quoted for TB and H2O pump is less than in my neck of the woods.
Originally Posted by JimBlake
ATF doesn't have to get dirty like engine-oil, so if it looked very different than the new stuff then you can do a couple more changes. The torque converter doesn't drain, so you can only drain about 1/3 of the total fluid. Drain & fill, then drive around (5 or 10 miles) & repeat. Or drain & fill again a couple weekends in a row if you don't feel like doing it all in one day. When it drains out reasonably clean, then you can go to the 30k intervals. (I'm not a big auto-trans guru, so hope someone else chimes in too)
Jeff247
Jan 4, 2016 07:32 PM
mihalis
Oct 11, 2011 05:00 PM
ajl05
Aug 14, 2009 08:58 AM
dragonle87
Mar 24, 2009 03:23 PM
rob3201
Jan 31, 2007 04:46 PM
