Rack pinion
Old Mar 21, 2010 | 03:00 PM
millsb's Avatar
Default Rack pinion
I have a 1991 Honda Accord EX I just replaced the rack pinion and outer tie rod ends and now two separate shop can not aligned the front has any one have this problem , I have checked the dimension of the old rack and tie and they match. I am stumped
Old Mar 21, 2010 | 03:01 PM
millsb's Avatar
Old Mar 21, 2010 | 03:50 PM
kris_loehr's Avatar
Is the problem negative or positive toe?
Old Mar 21, 2010 | 04:04 PM
millsb's Avatar
Default rack pinion
neg toe
Old Mar 21, 2010 | 04:12 PM
millsb's Avatar
Default rack pinion
neg toe
Old Mar 22, 2010 | 01:23 PM
kris_loehr's Avatar
it has ben awhile but I belive you need to remove the outer tie rods from the steering knuckle and thread them into further then reinstall into the knuckle. If this doesn't provide you the correct toe you need to compare the old and new rack and tie rods.
Old Mar 23, 2010 | 06:39 AM
millsb's Avatar
I have measured the rack and tie they all match length and dimension
noboundaries6289
Mar 6, 2008 10:12 AM
liam71234
Oct 17, 2007 11:25 AM
liam71234
Oct 7, 2007 09:54 AM
1186gibriadams
May 27, 2007 09:12 PM
1186gibriadams
May 27, 2007 09:00 PM
