rack and pinion
Old Jul 8, 2010 | 06:38 PM
pelon1416's Avatar
Default rack and pinion
I have a 90 honda accord ex, I have disconeted every thing from the rack and pinion, but I can not take it down the steering shaft will not allowe it to move, I have also dsiconected the shaft from the steering wheel.
Old Jul 8, 2010 | 10:19 PM
deserthonda's Avatar
did you remove and loosen the 2 ,10mm bolts at the bottom of the steering column??
there is a black cover with clips at bottom of steering cover it wraps around column,, you need to remove it, there is a joint that connects the column to the p/s rack,, remove the lower bolt, loosen the top bolt and slide the joint upward away from rack..
Old Jul 8, 2010 | 10:51 PM
pelon1416's Avatar
yes I have, the problem is because of that shaft it does not allowe the rack and pinion to move right or left far enough for the tie rod shaft to clear. I have also removed the tie rod ends.
Old Jul 8, 2010 | 11:29 PM
piece of cake......... while you hold the rack,,just grab one side of the tie rod and pull it all the way out ,,i think it is all the way out to the rt side ( passenger),, it will then clear ,,
Old Jul 8, 2010 | 11:35 PM
Talking
Up late there old man...WheelBrokerAng
Old Jul 9, 2010 | 08:17 AM
pelon1416's Avatar
I have tried that, but there is a welded bracket on both side that won't allowe clearence for the tie rod to come down. I have taken down the muffler, all the bolt for rack and pinion, the fluid lines, the bolt from the steering colum, is there anything else I'm missing? there is a bolt on each side holding part of the frame do I have to remove them?
Old Jul 9, 2010 | 05:08 PM
pelon1416's Avatar
Thank you very much, I took it out I was moving the hole unit instead of like you said the tie rod end. thanks again
noboundaries6289
Mar 6, 2008 10:12 AM
liam71234
Oct 17, 2007 11:25 AM
liam71234
Oct 7, 2007 09:54 AM
1186gibriadams
May 27, 2007 09:12 PM
1186gibriadams
May 27, 2007 09:00 PM
