Radiator tank Overflow.
Old Aug 27, 2010 | 04:12 PM
desfam5's Avatar
Default Radiator tank Overflow.
Homda accord lx 94
Is is usual for the radiator coolant holding tank to overflow? I filled it to the top level, and screwed down the cap. I drove it for around 5 miles, and then I switched the engine off. I heard this gurgling and bubbling sound, and I saw that my holding tank was overflowing. What could be wrong here?
BTW Can somebody please tell me where the thermostat is? I looked into the 2 bolt flange on the approx 2" hose coming off the radiator, and there was nothing in there. No Thermostat. Is it located somewhere else??
My cooling system has a leak or problem somewhere. Ever since I replaced the radiator, it has never worked perfectly.
Old Aug 27, 2010 | 04:30 PM
The thermostat is located where the lower radiator hose connects to the engine. The thermostat housing has a bleed valve on it and also a coolant temp sensor on it.
When you refilled your coolant, did you bleed the air from the system? That could cause all kinds of strange problems.
bluedemon
Dec 14, 2014 10:58 AM
camman
Aug 4, 2013 01:41 PM
faran
Jul 14, 2013 01:55 PM
mjhenks
Feb 11, 2010 07:40 AM
blackex19
Apr 16, 2007 05:06 AM
