1996 Accord Power Lock
Old Aug 26, 2010 | 12:54 PM
CHris6's Avatar
Default 1996 Accord Power Lock
Hi I just purchased a 96 Accord Lx as mentioned above, the key lock outside driver door won't lock or open or even make any noise. I checked the fuse but it was for all power locks. Shouldn't you be able to open your door without power locks, like mechanically? Also the driver door light won't work(I don't know if that's related) Didn't seem to be a common fuse so I doubt it. Thanks for all the future responses.
Old Aug 26, 2010 | 04:27 PM
Spray some WD-40 into the outside door lock to see if that frees it up.
I would guess that the bulb in the door is burned out and needs replaced.
Old Aug 26, 2010 | 07:09 PM
Does the key move and the lock does not change or will the key not turn?
Old Aug 27, 2010 | 09:51 AM
CHris6's Avatar
the key moves but nothing is happening
Old Aug 27, 2010 | 06:07 PM
Then I will assume the "lock rod" has come loose. I'd pull the door panel and see what is going on, could just be a clip or something else. Others might have different advise.
millmeg
Mar 22, 2015 03:09 PM
HateThisHonda
Sep 19, 2013 09:45 AM
bebo189
Oct 14, 2008 08:51 AM
MichaelEXL
Oct 22, 2005 07:13 PM
